Dell Inspiron 15 7579 Fan Replacement
  1. Dell Inspiron 15 7579 Fan Replacement, Back Panel: step 1, image 1 of 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Fan Replacement: step 2, image 1 of 2 Dell Inspiron 15 7579 Fan Replacement: step 2, image 2 of 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Fan Replacement, Fan: step 3, image 1 of 2 Dell Inspiron 15 7579 Fan Replacement, Fan: step 3, image 2 of 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 15 7579 Fan Replacement: step 4, image 2 of 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Fan Replacement: step 5, image 1 of 1
    • Carefully lift the fan out of the computer.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 227
