Dell Inspiron 15 7591 2-in-1 Trackpad Replacement
Griffin Nott
Griffin Nott and one other contributor
Last updated on June 1, 2022
15 minutes
Moderate
Community-Contributed Guide
Tools
Show more…
  1. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Opening the Laptop: step 1, image 1 of 2 Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Opening the Laptop: step 1, image 2 of 2
    • Unscrew the 7 Philips #000 screws.
    • Loosen the 2 Philips #000 screws. These screws do not come out but rather stay attached to the case.
    • With a suction cup lift the top and insert a plastic pry tool or guitar pick. Slide the pry tool from left to right. The panel should pop out slightly.
    • Work downwards with a pry tool on the right and left sides. The panel should pop up and be able to be removed.
  2. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Removing the Battery: step 2, image 1 of 1
    • Remove the 2 Philips #000 screws.
    • Loosen the Philips #000 screws. The screw is attached to the battery and will remain attached to the battery.
  3. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Disconnecting the Battery: step 3, image 1 of 1
    • Flip the battery upside down onto the motherboard.
    • Snake the wire out of its housing.
    • Disconnect the power connector.
  4. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement: step 4, image 1 of 1
    • Slide the battery in with the bottom first in order to attach the latches that are at the bottom.
    • Screw in the 2 Phillips #000 screws and tighten the 1 Phillips #000 screw attached to the battery.
  5. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Removing the Trackpad: step 5, image 1 of 1
    • After removing the battery in step 3 the track-pad is exposed.
    • Remove the 5 Phillips #000 screws.
    • Disconnect the blue ribbon connector.
Griffin Nott
181 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 257
