Dell Inspiron 15 Gaming 7577 Hard Drive Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • NOTE: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
  1. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Disconnecting the Hard Drive Cable: step 2, image 1 of 1
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Peeling the Hard Drive Cable: step 3, image 1 of 1
    • Peel off the hard-drive cable from the computer base.
  3. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws (M2.5x3) that secure the hard-drive assembly to the computer base.
  4. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 5, image 1 of 1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  5. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Disconnect the Inteposer: step 6, image 1 of 1
    • Disconnect the interposer from the hard-drive assembly.
  6. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Remove the Screws: step 7, image 1 of 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Lifting the Hard Drive Bracket: step 8, image 1 of 1
    • Lift the hard-drive bracket off the hard drive.
  8. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Align the Screw Holes: step 9, image 1 of 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  9. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Replace the Screws: step 10, image 1 of 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Connect the Interposer: step 11, image 1 of 1
    • Connect the interposer to the hard-drive assembly.
  11. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Align the Screw Holes: step 12, image 1 of 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Replace the Screws: step 13, image 1 of 1
    • Replace the four screws (M2.5x3) that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Adhering the Hard Drive Cable: step 14, image 1 of 1
    • Adhere the hard-drive cable to the computer base.
  14. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Sliding the Hard Drive Cable: step 15, image 1 of 1
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the hard-drive cable.
Finish Line
2 other people completed this guide.
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 3,218
