Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement
  1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: step 1, image 1 of 2 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: step 1, image 2 of 2
    • Place the laptop with the bottom panel facing up.
    • Remove the single screw to access the bottom panel.
  2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 2, image 1 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 2, image 2 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 2, image 3 of 3
    • Place a finger under the screw location and move it around the edge to pry the fourteen clips out.
    • There are six clips on each side of the panel and two on the edge by the screw.
    • Remove the bottom panel.
  3. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 3, image 1 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 3, image 2 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 3, image 3 of 3
    • Locate the M.2 drive to the right of the battery, below the hard drive.
    • Remove the screw on the edge of the drive.
  4. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 4, image 1 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 4, image 2 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 4, image 3 of 3
    • Lift up on the edge of the drive where the screw was.
    • Grab the drive by the two long edges.
    • Pull the drive out.
    • Note the keying on your new drive; it will only go in one way.
  5. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 5, image 1 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 5, image 2 of 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: step 5, image 3 of 3
    • Angle the new drive and insert it into the slot.
    • Apply pressure down on the screw end of the drive.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 43
All Time: 3,114
