Dell Inspiron 15 Memory Module Replacement
  1. Dell Inspiron 15 Memory Module Replacement, Popping up the Memory Module: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Using your fingertips, spread apart the securing clips at each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 Memory Module Replacement, Removing the Memory Module: step 2, image 1 of 2 Dell Inspiron 15 Memory Module Replacement, Removing the Memory Module: step 2, image 2 of 2
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 15 Memory Module Replacement, Align the Notch: step 3, image 1 of 2 Dell Inspiron 15 Memory Module Replacement, Align the Notch: step 3, image 2 of 2
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  4. Dell Inspiron 15 Memory Module Replacement: step 4, image 1 of 2 Dell Inspiron 15 Memory Module Replacement: step 4, image 2 of 2
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Finish Line
Terrence15
79,888 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 910
