Dell Inspiron 15 N5040 Hard Drive Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron 15 N5040 Hard Drive Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the two screws from the computer base.
  2. Dell Inspiron 15 N5040 Hard Drive Replacement, Sliding the Hard Drive: step 3, image 1 of 1
    • Slide the hard drive to the right to disconnect it from the connector on the system board.
  3. Dell Inspiron 15 N5040 Hard Drive Replacement, Lifting the Hard Drive: step 4, image 1 of 1
    • Lift the hard drive out of the computer base.
  4. Dell Inspiron 15 N5040 Hard Drive Replacement, Placing the Hard Drive: step 5, image 1 of 1
    • Place the NEW hard drive on the computer base.
  5. Dell Inspiron 15 N5040 Hard Drive Replacement, Push the Hard Drive: step 6, image 1 of 1
    • Push the hard drive towards the left to connect it to the connector on the system board.
  6. Dell Inspiron 15 N5040 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the two screws to the computer base.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
One Comment
Hello thank you for the information take care all the best in the new year
Greg Weber - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,072
