Dell Inspiron 15 Optical Drive Replacement
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 15 Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: step 2, image 1 of 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: step 3, image 1 of 2 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: step 3, image 2 of 2
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
3 other people completed this guide.
Edward Pacheco
833 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 4,734
