Dell Inspiron 15-3531 Hard Drive Replacement
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: step 2, image 1 of 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: step 2, image 2 of 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: step 2, image 3 of 3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: step 3, image 1 of 2 Dell Inspiron 15-3531 Hard Drive Replacement: step 3, image 2 of 2
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: step 4, image 1 of 3 Dell Inspiron 15-3531 Hard Drive Replacement: step 4, image 2 of 3 Dell Inspiron 15-3531 Hard Drive Replacement: step 4, image 3 of 3
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
Kody Dahlke
742 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Leahy Spring 2018 Member of USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,093
