Dell Inspiron 15-3542 LCD Screen Replacement
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: step 2, image 1 of 3 Dell Inspiron 15-3542 LCD Screen Replacement: step 2, image 2 of 3 Dell Inspiron 15-3542 LCD Screen Replacement: step 2, image 3 of 3
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: step 3, image 1 of 3 Dell Inspiron 15-3542 LCD Screen Replacement: step 3, image 2 of 3 Dell Inspiron 15-3542 LCD Screen Replacement: step 3, image 3 of 3
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: step 4, image 1 of 3 Dell Inspiron 15-3542 LCD Screen Replacement: step 4, image 2 of 3 Dell Inspiron 15-3542 LCD Screen Replacement: step 4, image 3 of 3
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Najeemdeen Lamidi
130 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,090
