Dell Inspiron 15-3543 Keyboard Replacement
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 15-3543 Keyboard Replacement: step 2, image 2 of 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron 15-3543 Keyboard Replacement: step 3, image 2 of 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
2 other people completed this guide.
One Comment
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 31
All Time: 1,079
