Dell Inspiron 15-5547 RAM Replacement
  1. Dell Inspiron 15-5547 RAM Replacement, RAM: step 1, image 1 of 2 Dell Inspiron 15-5547 RAM Replacement, RAM: step 1, image 2 of 2
    • Remove the two M2.5 x 5mm screws on the bottom of the laptop with the Phillips #0 screwdriver as shown.
  2. Dell Inspiron 15-5547 RAM Replacement: step 2, image 1 of 2 Dell Inspiron 15-5547 RAM Replacement: step 2, image 2 of 2
    • Use the Jimmy to pry off the back cover of the laptop.
    • Carefully lift and remove the back cover of the laptop.
  3. Dell Inspiron 15-5547 RAM Replacement: step 3, image 1 of 3 Dell Inspiron 15-5547 RAM Replacement: step 3, image 2 of 3 Dell Inspiron 15-5547 RAM Replacement: step 3, image 3 of 3
    • The RAM components of the laptop can be found in the following locations.
    • Pull the two side brackets of the bottom RAM component horizontally. This will free the component.
    • Lift and remove the RAM component from its location.
    • Be careful with the RAM components as they are fragile.
  4. Dell Inspiron 15-5547 RAM Replacement: step 4, image 1 of 2 Dell Inspiron 15-5547 RAM Replacement: step 4, image 2 of 2
    • Repeat the previous steps for the top RAM slot.
    • Apply slight pressure onto the RAM to lock it in during the reassembly.
2 other people completed this guide.
Keegan Tucker
256 Reputation
1 Guide authored
IUPUI, Team S1-G3, Harley Summer 2019 Member of IUPUI, Team S1-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S1G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 851
