Dell Inspiron 15-5558 Hard Drive Replacement
  1. Dell Inspiron 15-5558 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Hard Drive Replacement: step 2, image 1 of 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Hard Drive Replacement: step 3, image 1 of 2 Dell Inspiron 15-5558 Hard Drive Replacement: step 3, image 2 of 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 Hard Drive Replacement: step 5, image 1 of 3 Dell Inspiron 15-5558 Hard Drive Replacement: step 5, image 2 of 3 Dell Inspiron 15-5558 Hard Drive Replacement: step 5, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
4 other people completed this guide.
Adam Lourenco
775 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 29
All Time: 4,751
