Dell Inspiron 15-5558 Keyboard Replacement
  1. Dell Inspiron 15-5558 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Keyboard Replacement: step 2, image 1 of 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Keyboard Replacement: step 3, image 1 of 2 Dell Inspiron 15-5558 Keyboard Replacement: step 3, image 2 of 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: step 4, image 3 of 3
    • Identify the two small slots along the side of the keyboard closest to the screen.
    • Wedge the spudger in the two small slots and push the spudger in and down to detach the pins.
    • Using your hands, pull the keyboard up and out.
  5. Dell Inspiron 15-5558 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron 15-5558 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron 15-5558 Keyboard Replacement: step 5, image 3 of 3
    • At the end of the ribbon cable attaching the keyboard to the device is a bar secure.
    • Using your finger or spudger, flip the bar up and the keyboard will be freed from the device.
5 other people completed this guide.
Adam Lourenco
811 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 2,150
