Dell Inspiron 15-5558 Memory Modules Replacement
Terrence15
Terrence15 and 2 other contributors
Last updated on November 23, 2019
2 - 4 minutes
Very easy
Community-Contributed Guide
Introduction
Go to step 1
In this guide, we will be showing you how to remove and replace the Memory Modules.
  1. Dell Inspiron 15-5558 Memory Modules Replacement, Popping up the Memory Module: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15-5558 Memory Modules Replacement, Remove the Memory Module: step 2, image 1 of 1
    • Remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  3. Dell Inspiron 15-5558 Memory Modules Replacement, Remove the Memory Module: step 4, image 1 of 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Finish Line
Terrence15
79,522 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 568
