Dell Inspiron 15-5559 CD Drive Replacement
  1. Dell Inspiron 15-5559 CD Drive Replacement, CD Drive: step 1, image 1 of 1
    • Use the Philips #1 to remove the two (2) 2.5x8mm screws that anchor the CD Drive.
    • It is important that the correct screw driver is used to remove the screws to prevent damaging them.
  2. Dell Inspiron 15-5559 CD Drive Replacement: step 2, image 1 of 3 Dell Inspiron 15-5559 CD Drive Replacement: step 2, image 2 of 3 Dell Inspiron 15-5559 CD Drive Replacement: step 2, image 3 of 3
    • Place the spudger at the spot indicated by the red circle.
    • Use your hand to pull the CD drive out while using the spudger as leverage to push the CD drive out.
Kyla Ward
580 Reputation
4 Guides authored
Baylor, Team S5-G5, Williams Spring 2018 Member of Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,582
