Dell Inspiron 15-5559 Hard Drive Replacement
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: step 2, image 1 of 2 Dell Inspiron 15-5559 Hard Drive Replacement: step 2, image 2 of 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: step 4, image 1 of 1
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: step 5, image 1 of 2 Dell Inspiron 15-5559 Hard Drive Replacement: step 5, image 2 of 2
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
4 other people completed this guide.
Kyla Ward
580 Reputation
4 Guides authored
Baylor, Team S5-G5, Williams Spring 2018 Member of Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Members
5 Guides authored
2 Comments
The blue part came off is that important?
walterandradeconde - Reply
can i put this in a harddrive enclosure?
chiggly 123 - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 5,254
