Dell Inspiron 15-5559 RAM Replacement
  1. Dell Inspiron 15-5559 RAM Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-5559 RAM Replacement, Back Panel: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 RAM Replacement: step 2, image 1 of 2 Dell Inspiron 15-5559 RAM Replacement: step 2, image 2 of 2
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 RAM Replacement, RAM: step 3, image 1 of 3 Dell Inspiron 15-5559 RAM Replacement, RAM: step 3, image 2 of 3 Dell Inspiron 15-5559 RAM Replacement, RAM: step 3, image 3 of 3
    • Place a finger on each of the 2 metal prongs on either side of the RAM stick and apply light pressure to release the RAM stick.
    • Remove the first stick of RAM. Repeat this process for the second RAM stick.
Kyla Ward
580 Reputation
4 Guides authored
Baylor, Team S5-G5, Williams Spring 2018 Member of Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 1,633
