Dell Inspiron 15-5567 Battery Replacement
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: step 1, image 1 of 1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: step 2, image 1 of 3 Dell Inspiron 15-5567 Battery Replacement: step 2, image 2 of 3 Dell Inspiron 15-5567 Battery Replacement: step 2, image 3 of 3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: step 3, image 1 of 2 Dell Inspiron 15-5567 Battery Replacement: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 15-5567 Battery Replacement: step 4, image 2 of 2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: step 5, image 1 of 2 Dell Inspiron 15-5567 Battery Replacement: step 5, image 2 of 2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
5 other people completed this guide.
Saaed Chaudhry
382 Reputation
2 Guides authored
One Comment
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 62
All Time: 7,616
