Dell Inspiron 15-5567 Display Assembly Replacement
  1. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Display Cable: step 1, image 1 of 1
  2. Dell Inspiron 15-5567 Display Assembly Replacement, Note the Display Cable Routing: step 2, image 1 of 1
    • Note the display cable routing and remove the cable from its routing guides.
  3. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: step 3, image 1 of 2 Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: step 3, image 2 of 2
    • Lift the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Display Assembly Replacement, Open the Display Hinges: step 5, image 1 of 1
    • Open the display hinges.
  6. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Palm Rest: step 6, image 1 of 1
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 15-5567 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 1
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Dell Inspiron 15-5567 Display Assembly Replacement, Press the Display Hinges: step 8, image 1 of 1
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Dell Inspiron 15-5567 Display Assembly Replacement, Replace the Screws: step 9, image 1 of 1
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Dell Inspiron 15-5567 Display Assembly Replacement, Routing the Display Cable: step 10, image 1 of 1
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Dell Inspiron 15-5567 Display Assembly Replacement, Sliding the Display Cable: step 11, image 1 of 1
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
Finish Line
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
One Comment
Nice, is the part available?
gideon onwuka - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 2,102
