Dell Inspiron 15-5567 Hard Drive Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Dell Inspiron 15-5567 Hard Drive Replacement, Lifting the Latch: step 1, image 1 of 3 Dell Inspiron 15-5567 Hard Drive Replacement, Lifting the Latch: step 1, image 2 of 3 Dell Inspiron 15-5567 Hard Drive Replacement, Lifting the Latch: step 1, image 3 of 3
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • Lift the latch and using the pull tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15-5567 Hard Drive Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  3. Dell Inspiron 15-5567 Hard Drive Replacement, Lifting the Hard Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  4. Dell Inspiron 15-5567 Hard Drive Replacement, Disconnecting the Interposer: step 4, image 1 of 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15-5567 Hard Drive Replacement, Remove the Screws: step 5, image 1 of 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15-5567 Hard Drive Replacement, Lifting the Hard Drive: step 6, image 1 of 2 Dell Inspiron 15-5567 Hard Drive Replacement, Lifting the Hard Drive: step 6, image 2 of 2
    • Lift the hard drive off the hard-drive bracket.
  7. Dell Inspiron 15-5567 Hard Drive Replacement, Align the Screw Holes: step 7, image 1 of 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  8. Dell Inspiron 15-5567 Hard Drive Replacement, Replace the Screws: step 8, image 1 of 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15-5567 Hard Drive Replacement, Connecting the Interposer: step 9, image 1 of 1
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15-5567 Hard Drive Replacement, Align the Screw Holes: step 10, image 1 of 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  11. Dell Inspiron 15-5567 Hard Drive Replacement, Replace the Screws: step 11, image 1 of 1
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  12. Dell Inspiron 15-5567 Hard Drive Replacement, Connect the Hard-Drive Cable: step 12, image 1 of 1
    • Connect the hard-drive cable to the system board and close the latch to secure the cable.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,574
