Dell Inspiron 15-5567 Hard Drive Replacement
  1. Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove thirteen 8.5 mm screws from the bottom of the laptop.
    • Using the same screwdriver, remove the two 3.2 mm screws and slide the DVD drive out of the laptop.
  2. Dell Inspiron 15-5567 Hard Drive Replacement: step 2, image 1 of 3 Dell Inspiron 15-5567 Hard Drive Replacement: step 2, image 2 of 3 Dell Inspiron 15-5567 Hard Drive Replacement: step 2, image 3 of 3
    • Remove the three 2.3 mm screws underneath the CD drive using the Phillips #0 screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Hard Drive Replacement: step 3, image 1 of 2 Dell Inspiron 15-5567 Hard Drive Replacement: step 3, image 2 of 2
    • Disconnect cable covering the hard drive by prying up on the clamp holding the cable.
    • Disconnect the cable from the motherboard.
  4. Dell Inspiron 15-5567 Hard Drive Replacement: step 4, image 1 of 2 Dell Inspiron 15-5567 Hard Drive Replacement: step 4, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the three 5.6 mm screws from the hard drive.
    • Remove the old hard drive from the laptop.
Saaed Chaudhry
382 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 57
All Time: 2,272
