Dell Inspiron 15-5567 I/O Board/Cable Replacement
  1. Dell Inspiron 15-5567 I/O Board/Cable Replacement, Back Cover: step 1, image 1 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement, Back Cover: step 1, image 2 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement, Back Cover: step 1, image 3 of 3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 2, image 1 of 2 Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 2, image 2 of 2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 3, image 1 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 3, image 2 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 3, image 3 of 3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 I/O Board/Cable Replacement, I/O Board/Cable: step 4, image 1 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement, I/O Board/Cable: step 4, image 2 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement, I/O Board/Cable: step 4, image 3 of 3
    • Open the latch for the cable using the blue opening tool by placing it under the latch (like in the second picture) and lifting it upward.
    • Disconnect the cable by pulling the blue tab.
  5. Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 5, image 1 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 5, image 2 of 3 Dell Inspiron 15-5567 I/O Board/Cable Replacement: step 5, image 3 of 3
    • Remove one M2.5x5mm screw securing the board using a Philips #0.
    • Lift the board gently and remove it.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 703
