Introduction
The battery is needed to power the laptop. A bad battery must be replaced, which can be done with this guide.
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
4 other people completed this guide.
