Dell Inspiron 15-7537 Hard Drive Replacement
  1. Dell Inspiron 15-7537 Hard Drive Replacement, Bottom Case: step 1, image 1 of 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Hard Drive Replacement: step 3, image 1 of 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
6 other people completed this guide.
Jean Whitmore
984 Reputation
7 Guides authored
Cal Poly, Team 18-2, Maness Winter 2015 Member of Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 6,999
