Dell Inspiron 15-7537 Keyboard Replacement
  1. Dell Inspiron 15-7537 Keyboard Replacement, Bottom Case: step 1, image 1 of 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Keyboard Replacement: step 2, image 1 of 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Keyboard Replacement: step 3, image 1 of 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Keyboard Replacement, Battery: step 4, image 1 of 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Keyboard Replacement: step 5, image 1 of 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
  6. Dell Inspiron 15-7537 Keyboard Replacement, Removing the Keyboard: step 6, image 1 of 1
    • Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
  7. Dell Inspiron 15-7537 Keyboard Replacement: step 7, image 1 of 1
    • Flip over the computer and open the display as far as it can go.
    • Use the spudger to remove the keyboard from the palm assembly.
  8. Dell Inspiron 15-7537 Keyboard Replacement: step 8, image 1 of 1
    • Gently flip over the keyboard and place it on the palm rest assembly.
    • Lift the connector latches and disconnect the keyboard and the keyboard back-light cables.
  9. Dell Inspiron 15-7537 Keyboard Replacement: step 9, image 1 of 3 Dell Inspiron 15-7537 Keyboard Replacement: step 9, image 2 of 3 Dell Inspiron 15-7537 Keyboard Replacement: step 9, image 3 of 3
    • Take the keyboard off the palm rest assembly.
11 other people completed this guide.
Jean Whitmore
984 Reputation
7 Guides authored
Cal Poly, Team 18-2, Maness Winter 2015 Member of Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Members
8 Guides authored
3 Comments
Great guide, thanks for the help!
Patrick S - Reply
Thanks It’s Useful
ahmed omar - Reply
It is important to note that the little black clips on the ends of the keyboard wires SWIVEL UP! I broke mine because nothing in this guide told me how to get the wires out properly.
benton.addison - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 32
All Time: 6,647
