Dell Inspiron 15-7537 Wireless Card Replacement
  1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: step 1, image 1 of 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Wireless Card Replacement: step 2, image 1 of 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Wireless Card Replacement: step 3, image 1 of 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: step 4, image 1 of 2 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: step 4, image 2 of 2
    • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
  5. Dell Inspiron 15-7537 Wireless Card Replacement: step 5, image 1 of 1
    • Disconnect the two antennas (one black and one white) from the wireless card.
  6. Dell Inspiron 15-7537 Wireless Card Replacement: step 6, image 1 of 1
    • Remove the WiFi card.
    • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
    • Avoid damaging the card by not placing any cables underneath the card.
Finish Line
Jean Whitmore
984 Reputation
7 Guides authored
Cal Poly, Team 18-2, Maness Winter 2015 Member of Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 3,672
