Dell Inspiron 15-7547 Battery Replacement
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: step 2, image 1 of 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 15-7547 Battery Replacement, Battery: step 3, image 2 of 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 Battery Replacement: step 4, image 2 of 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: step 5, image 1 of 3 Dell Inspiron 15-7547 Battery Replacement: step 5, image 2 of 3 Dell Inspiron 15-7547 Battery Replacement: step 5, image 3 of 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 25
All Time: 2,216
