Dell Inspiron 15-7547 Hard Drive Replacement
  1. Dell Inspiron 15-7547 Hard Drive Replacement, Bottom Cover: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Hard Drive Replacement: step 2, image 1 of 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  4. Dell Inspiron 15-7547 Hard Drive Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 Hard Drive Replacement: step 4, image 2 of 2
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  5. Dell Inspiron 15-7547 Hard Drive Replacement: step 5, image 1 of 1
    • Lift the hard drive out of the chassis.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 740
