Dell Inspiron 15-7547 RAM Replacement
  1. Dell Inspiron 15-7547 RAM Replacement, Bottom Cover: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 RAM Replacement: step 2, image 1 of 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 RAM Replacement, RAM: step 3, image 1 of 3 Dell Inspiron 15-7547 RAM Replacement, RAM: step 3, image 2 of 3 Dell Inspiron 15-7547 RAM Replacement, RAM: step 3, image 3 of 3
    • Remove the plastic heat spreader that covers the RAM sticks.
  4. Dell Inspiron 15-7547 RAM Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 RAM Replacement: step 4, image 2 of 2
    • Release the clamps on each side of the RAM sticks by pushing away from the center.
    • When done properly the RAM stick should pop up.
  5. Dell Inspiron 15-7547 RAM Replacement: step 5, image 1 of 2 Dell Inspiron 15-7547 RAM Replacement: step 5, image 2 of 2
    • Pull the RAM stick in a straight line out of the socket.
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 19
All Time: 343
