Dell Inspiron 15-7548 Power Port Replacement
  1. Dell Inspiron 15-7548  Power Port Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement, Back Panel: step 1, image 2 of 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548  Power Port Replacement: step 2, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement: step 2, image 2 of 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548  Power Port Replacement, Power Port: step 3, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement, Power Port: step 3, image 2 of 2
    • Grab the wires and lightly pull to remove the power port from the motherboard.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 550
