Dell Inspiron 15-7559 Keyboard Replacement
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 15-7559 Keyboard Replacement: step 2, image 2 of 2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: step 3, image 1 of 3 Dell Inspiron 15-7559 Keyboard Replacement: step 3, image 2 of 3 Dell Inspiron 15-7559 Keyboard Replacement: step 3, image 3 of 3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: step 4, image 1 of 1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
8 other people completed this guide.
Trenton Greevebiester
1,536 Reputation
6 Guides authored
UW Tacoma, Team S3-G2, Liner Fall 2017 Member of UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Members
9 Guides authored
2 Comments
How to put it back
Using Name - Reply
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 42
All Time: 6,929
