Dell Inspiron 15-7567 Wireless Card Replacement
  1. Dell Inspiron 15-7567 Wireless Card  Replacement, Battery: step 1, image 1 of 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Wireless Card  Replacement: step 2, image 1 of 2 Dell Inspiron 15-7567 Wireless Card  Replacement: step 2, image 2 of 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Wireless Card  Replacement: step 3, image 1 of 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Wireless Card  Replacement: step 4, image 1 of 2 Dell Inspiron 15-7567 Wireless Card  Replacement: step 4, image 2 of 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Wireless Card  Replacement: step 5, image 1 of 2 Dell Inspiron 15-7567 Wireless Card  Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Wireless Card  Replacement: step 6, image 1 of 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: step 7, image 1 of 2 Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: step 7, image 2 of 2
    • Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
    • Remove the grey panel as well.
  8. Dell Inspiron 15-7567 Wireless Card  Replacement: step 8, image 1 of 1
    • Detach the black and white wires connected to the card by gently lifting up on the wires.
  9. Dell Inspiron 15-7567 Wireless Card  Replacement: step 9, image 1 of 2 Dell Inspiron 15-7567 Wireless Card  Replacement: step 9, image 2 of 2
    • Gently pull the wireless card out at an angle towards you.
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 16
All Time: 799
