Dell Inspiron 1501 Optical Drive Replacement
  1. Dell Inspiron 1501 Optical Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1501 Optical Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1501 Optical Drive Replacement, Battery: step 1, image 3 of 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 Optical Drive Replacement, Optical Drive: step 2, image 1 of 2 Dell Inspiron 1501 Optical Drive Replacement, Optical Drive: step 2, image 2 of 2
    • Remove the JIS #1 8mm screw from above the upper right corner of where the battery was.
  3. Dell Inspiron 1501 Optical Drive Replacement: step 3, image 1 of 1
    • Pull the optical drive out.
Ravon Williams
169 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 317
