Dell Inspiron 1501 RAM Replacement
  1. Dell Inspiron 1501 RAM Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1501 RAM Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1501 RAM Replacement, Battery: step 1, image 3 of 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Dell Inspiron 1501 RAM Replacement, RAM: step 2, image 1 of 3 Dell Inspiron 1501 RAM Replacement, RAM: step 2, image 2 of 3 Dell Inspiron 1501 RAM Replacement, RAM: step 2, image 3 of 3
    • Loosen the two JIS #1 8mm screws on the cover.
    • Lift and remove the cover.
  3. Dell Inspiron 1501 RAM Replacement: step 3, image 1 of 2 Dell Inspiron 1501 RAM Replacement: step 3, image 2 of 2
    • Pull the two metal clips holding down the card apart.
    • Lift and pull out the card.
Ravon Williams
184 Reputation
2 Guides authored
1 Guide Comment
dell 1501 memory cover par
shahzad bashir - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 23
All Time: 840
