Dell Inspiron 1520 Hard Drive Replacement
  1. Dell Inspiron 1520 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • Follow the procedures in Before You Begin.
    • Turn the computer over.
    • Remove the four M3 x 3-mm screws that secure the hard drive.
  2. Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: step 2, image 1 of 1
    • Slide the hard drive out of the computer.
  3. Dell Inspiron 1520 Hard Drive Replacement, Remove the Screws: step 3, image 1 of 1
    • Remove the two M3 x 3-mm screws from each side of the hard drive bezel, then pull to separate the bezel from the hard drive.
  4. Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: step 4, image 1 of 2 Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: step 4, image 2 of 2
    • Slide the hard drive bezel onto the NEW hard drive, then tighten the two M3 x 3-mm screws to secure the bezel to the drive.
    • NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
  5. Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: step 5, image 1 of 1
    • Slide the hard drive into the hard drive bay until the drive is fully seated.
  6. Dell Inspiron 1520 Hard Drive Replacement, Replace the Screws: step 6, image 1 of 1
    • Replace the four M3 x 3-mm screws to secure the hard drive.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 892
