Dell Inspiron 1521 RAM Replacement
  1. Dell Inspiron 1521 RAM Replacement, Battery: step 1, image 1 of 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 RAM Replacement: step 2, image 1 of 3 Dell Inspiron 1521 RAM Replacement: step 2, image 2 of 3 Dell Inspiron 1521 RAM Replacement: step 2, image 3 of 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 RAM Replacement, RAM: step 3, image 1 of 2 Dell Inspiron 1521 RAM Replacement, RAM: step 3, image 2 of 2
    • Locate the Phillips #1 screw securing panel M.
    • Remove the screw from panel M with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 RAM Replacement: step 4, image 1 of 3 Dell Inspiron 1521 RAM Replacement: step 4, image 2 of 3 Dell Inspiron 1521 RAM Replacement: step 4, image 3 of 3
    • Pry the panel open with the plastic opening tool.
    • Gently pull with your fingers to remove the panel.
  5. Dell Inspiron 1521 RAM Replacement: step 5, image 1 of 3 Dell Inspiron 1521 RAM Replacement: step 5, image 2 of 3 Dell Inspiron 1521 RAM Replacement: step 5, image 3 of 3
    • Identify the metal tabs holding the RAM in place.
    • Gently press outward on the tabs at the same time with your fingers to release the RAM.
    • Gently pull the RAM outward with your fingers to remove it.
Nikolaus Powell
426 Reputation
3 Guides authored
Cal Poly, Team 15-47, Forte Fall 2012 Member of Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 3,541
