Dell Inspiron 1525 Keyboard Replacement
  1. Dell Inspiron 1525 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 1525 Keyboard Replacement: step 2, image 2 of 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Keyboard Replacement, Central Control Cover: step 3, image 1 of 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Keyboard Replacement: step 4, image 1 of 3 Dell Inspiron 1525 Keyboard Replacement: step 4, image 2 of 3 Dell Inspiron 1525 Keyboard Replacement: step 4, image 3 of 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron 1525 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron 1525 Keyboard Replacement: step 5, image 3 of 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  6. Dell Inspiron 1525 Keyboard Replacement, Keyboard: step 6, image 1 of 2 Dell Inspiron 1525 Keyboard Replacement, Keyboard: step 6, image 2 of 2
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  7. Dell Inspiron 1525 Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron 1525 Keyboard Replacement: step 7, image 2 of 2
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
11 other people completed this guide.
3 Comments
why did you say to remove the central control cover? It is so hard top get it back! Especially when the guide on laptopkeyboard.com seems to suggest that this is unnecessary.
sally wise - Reply
Thank you so much…!
amal. k.manoj - Reply
thanks, marvelous site . I am in
Nasser Dardier - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 14,199
