Dell Inspiron 1526 Heat Sink Replacement
  1. Dell Inspiron 1526 Heat Sink Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1526 Heat Sink Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1526 Heat Sink Replacement, Battery: step 1, image 3 of 3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: step 2, image 1 of 2 Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the eight 3mm screws from the rear casing of the laptop.
  3. Dell Inspiron 1526 Heat Sink Replacement: step 3, image 1 of 2 Dell Inspiron 1526 Heat Sink Replacement: step 3, image 2 of 2
    • Loosen the five captive Phillips #0 screws from the heat sink.
    • Lift the heat sink from the motherboard.
  4. Dell Inspiron 1526 Heat Sink Replacement: step 4, image 1 of 2 Dell Inspiron 1526 Heat Sink Replacement: step 4, image 2 of 2
    • Apply a pea-sized amount of new thermal paste to the CPU and GPU.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 32
All Time: 230
