Dell Inspiron 1526 Screen Replacement
  1. Dell Inspiron 1526 Screen Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1526 Screen Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1526 Screen Replacement, Battery: step 1, image 3 of 3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Screen Replacement, Keyboard: step 2, image 1 of 1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Screen Replacement: step 3, image 1 of 1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Screen Replacement: step 4, image 1 of 1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Screen Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Screen Replacement: step 6, image 1 of 2 Dell Inspiron 1526 Screen Replacement: step 6, image 2 of 2
    • Remove the control cover.
  7. Dell Inspiron 1526 Screen Replacement: step 7, image 1 of 1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Screen Replacement: step 8, image 1 of 1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Screen Replacement: step 9, image 1 of 2 Dell Inspiron 1526 Screen Replacement: step 9, image 2 of 2
    • Remove the keyboard.
  10. Dell Inspiron 1526 Screen Replacement, Screen: step 10, image 1 of 2 Dell Inspiron 1526 Screen Replacement, Screen: step 10, image 2 of 2
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Screen Replacement: step 11, image 1 of 3 Dell Inspiron 1526 Screen Replacement: step 11, image 2 of 3 Dell Inspiron 1526 Screen Replacement: step 11, image 3 of 3
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Screen Replacement: step 12, image 1 of 2 Dell Inspiron 1526 Screen Replacement: step 12, image 2 of 2
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 29
All Time: 238
