Dell Inspiron 1545 CPU Heat Sink Replacement
  1. Dell Inspiron 1545 CPU Heat Sink Replacement, Battery: step 1, image 1 of 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 CPU Heat Sink Replacement: step 2, image 1 of 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 CPU Heat Sink Replacement: step 3, image 1 of 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 CPU Heat Sink Replacement, Base Cover: step 4, image 1 of 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 CPU Heat Sink Replacement: step 5, image 1 of 2 Dell Inspiron 1545 CPU Heat Sink Replacement: step 5, image 2 of 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 CPU Heat Sink Replacement, CPU Heat Sink: step 6, image 1 of 1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 CPU Heat Sink Replacement: step 7, image 1 of 1
    • Pull up on the Heat Sink unit to remove it.
6 other people completed this guide.
Nathan Lemay
3,064 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,076
