Dell Inspiron 1545 Memory Module Replacement
  1. Dell Inspiron 1545 Memory Module Replacement, Popping up the Memory Module: step 1, image 1 of 1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Dell Inspiron 1545 Memory Module Replacement, Remove the Memory Module: step 2, image 1 of 1
    • Remove the memory module from the connector.
  3. Dell Inspiron 1545 Memory Module Replacement, Align the Notch: step 3, image 1 of 2 Dell Inspiron 1545 Memory Module Replacement, Align the Notch: step 3, image 2 of 2
    • Align the notch in the edge of the NEW memory module with the tab in the memory module connector.
  4. Dell Inspiron 1545 Memory Module Replacement, Sliding the Module: step 4, image 1 of 1
    • Slide the module firmly into the slot at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Finish Line
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 996
