Dell Inspiron 1545 Optical Disk Drive Replacement
  1. Dell Inspiron 1545 Optical Disk Drive Replacement, Battery: step 1, image 1 of 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Optical Disk Drive Replacement: step 2, image 1 of 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Optical Disk Drive Replacement: step 3, image 1 of 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Optical Disk Drive Replacement, Optical Disk Drive: step 4, image 1 of 1
    • Flip the laptop to its back side.
    • Remove the screw (5mm Phillips #1) that secures the Optical Disk Drive on the back of the laptop.
  5. Dell Inspiron 1545 Optical Disk Drive Replacement: step 5, image 1 of 3 Dell Inspiron 1545 Optical Disk Drive Replacement: step 5, image 2 of 3 Dell Inspiron 1545 Optical Disk Drive Replacement: step 5, image 3 of 3
    • Push the Optical Disk Drive out using a spudger tool as shown and pull from the front cover of the Optical Disk Drive.
3 other people completed this guide.
Nathan Lemay
3,064 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,169
