Dell Inspiron 1545 RAM Replacement
  1. Dell Inspiron 1545 RAM Replacement, Battery: step 1, image 1 of 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 RAM Replacement: step 2, image 1 of 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 RAM Replacement: step 3, image 1 of 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 RAM Replacement, Base Cover: step 4, image 1 of 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 RAM Replacement: step 5, image 1 of 2 Dell Inspiron 1545 RAM Replacement: step 5, image 2 of 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 RAM Replacement, RAM: step 6, image 1 of 1
    • Spread apart the securing clips on each end of the memory stick until the memory stick pops up.
    • Remove the memory stick from the laptop.
    • Repeat these steps to remove the second memory stick.
11 other people completed this guide.
Nathan Lemay
3,145 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 3,291
