Dell Inspiron 1546 Hard Drive Replacement
  1. Dell Inspiron 1546 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard drive assembly to the computer base.
  2. Dell Inspiron 1546 Hard Drive Replacement, Sliding the Hard Drive Assembly: step 2, image 1 of 1
    • Slide the hard drive assembly out of the hard drive compartment.
  3. Dell Inspiron 1546 Hard Drive Replacement, Remove the Screws: step 3, image 1 of 1
    • Remove the two screws that secure the hard drive bezel to the hard drive.
  4. Dell Inspiron 1546 Hard Drive Replacement, Lifting the Hard Drive: step 4, image 1 of 2 Dell Inspiron 1546 Hard Drive Replacement, Lifting the Hard Drive: step 4, image 2 of 2
    • Lift the hard drive bezel off the hard drive.
  5. Dell Inspiron 1546 Hard Drive Replacement, Align the Screw Holes: step 5, image 1 of 1
    • Align the screw holes on the hard drive bezel with the holes on the NEW hard drive.
  6. Dell Inspiron 1546 Hard Drive Replacement, Replace the Screws: step 6, image 1 of 1
    • Replace the two screws that secure the hard drive bezel to the hard drive.
  7. Dell Inspiron 1546 Hard Drive Replacement, Sliding the Hard Drive Assembly: step 7, image 1 of 1
    • Slide the hard drive assembly into the hard drive compartment until it is fully seated.
  8. Dell Inspiron 1546 Hard Drive Replacement, Replace the Screws: step 8, image 1 of 1
    • Replace the two screws that secure the hard drive assembly to the computer base.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 191
