Dell Inspiron 1564 Hard Drive Replacement
  1. Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: step 1, image 1 of 2 Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: step 1, image 2 of 2
    • Locate battery latch on bottom of computer and slide to right.
    • While holding battery latch, pull the battery away from device and the battery will come free.
  2. Dell Inspiron 1564 Hard Drive Replacement, Remove Bottom Cover Screws: step 2, image 1 of 1
    • With a J0 screwdriver bit, loosen all screws from the backing above the battery latch and remove the covering.
  3. Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: step 3, image 1 of 2 Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: step 3, image 2 of 2
    • Locate the three 4mm screws securing the hard drive and unscrew them with a J0 screwdriver.
    • Slide the hard drive to the left to unplug the SATA data and SATA power cables, then gently pry upwards and pull the drive away from device.
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,961
