Dell Inspiron 15R Keyboard Replacement
Trixie Gonzalez
Trixie Gonzalez and 3 other contributors
Last updated on August 28, 2015
10 - 15 minutes
Moderate
Introduction
Go to step 1
If most keys on your keyboard are not working, this guide will help you replace the keyboard.
Tools
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell Inspiron 15R Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the device over and locate the battery.
  2. Dell Inspiron 15R Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 2, image 2 of 2
    • Place thumbs on each latch and push outwards.
  3. Dell Inspiron 15R Keyboard Replacement: step 3, image 1 of 1
    • Push and slide the battery away from you.
  4. Dell Inspiron 15R Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Inspiron 15R Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Inspiron 15R Keyboard Replacement, Keyboard: step 4, image 3 of 3
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
  5. Dell Inspiron 15R Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 5, image 2 of 2
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
  6. Dell Inspiron 15R Keyboard Replacement: step 6, image 1 of 1
    • Turn the device around and open it up.
  7. Dell Inspiron 15R Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 7, image 2 of 2
    • Using your index finger, push down on the F1 and F7 keys.
  8. Dell Inspiron 15R Keyboard Replacement: step 8, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 8, image 2 of 2
    • Using your index finger, push down on the x icon and Home keys.
  9. Dell Inspiron 15R Keyboard Replacement: step 9, image 1 of 3 Dell Inspiron 15R Keyboard Replacement: step 9, image 2 of 3 Dell Inspiron 15R Keyboard Replacement: step 9, image 3 of 3
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
  10. Dell Inspiron 15R Keyboard Replacement: step 10, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 10, image 2 of 2
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
  11. Dell Inspiron 15R Keyboard Replacement: step 11, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 11, image 2 of 2
    • Carefully pull and turn the keyboard over.
  12. Dell Inspiron 15R Keyboard Replacement: step 12, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 12, image 2 of 2
    • Lift the black lever.
  13. Dell Inspiron 15R Keyboard Replacement: step 13, image 1 of 2 Dell Inspiron 15R Keyboard Replacement: step 13, image 2 of 2
    • Remove the keyboard cable
Trixie Gonzalez
843 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,356
