Dell Inspiron 15R N5110 Memory Module Replacement
  1. Dell Inspiron 15R N5110 Memory Module Replacement, Loosen the Screw: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15R N5110 Memory Module Replacement, Lifting the Memory Module Cover: step 2, image 1 of 1
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15R N5110 Memory Module Replacement, Popping up the Memory Module: step 3, image 1 of 2 Dell Inspiron 15R N5110 Memory Module Replacement, Popping up the Memory Module: step 3, image 2 of 2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Dell Inspiron 15R N5110 Memory Module Replacement, Remove the Memory Module: step 4, image 1 of 1
    • Remove the memory module from the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  5. Dell Inspiron 15R N5110 Memory Module Replacement, Sliding the Memory Module: step 6, image 1 of 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  6. Dell Inspiron 15R N5110 Memory Module Replacement, Slide the Tabs: step 7, image 1 of 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  7. Dell Inspiron 15R N5110 Memory Module Replacement, Tighten the Screw: step 8, image 1 of 1
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 354
