Dell Inspiron 15R SE 7520 Hard Drive Replacement
  1. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Sliding the Hard Drive: step 2, image 1 of 1
    • Using the pull-tab, slide the hard-drive assembly toward the back of the computer to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard Drive: step 5, image 1 of 2 Dell Inspiron 15R SE 7520 Hard Drive Replacement, Lifting the Hard Drive: step 5, image 2 of 2
    • Lift the hard drive off the hard-drive bracket.
  6. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Align the Screw Holes: step 6, image 1 of 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Place the Hard-Drive Assembly: step 8, image 1 of 1
    • Place the hard-drive assembly on the computer base.
  9. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Sliding the Hard Drive Assembly: step 9, image 1 of 1
    • Using the pull-tab, slide the hard-drive assembly toward the front of the computer, to connect the hard-drive assembly to the connector on the system board.
  10. Dell Inspiron 15R SE 7520 Hard Drive Replacement, Replace the Screws: step 10, image 1 of 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,021
