Dell Inspiron 15R Screen Replacement
  1. Dell Inspiron 15R Screen Replacement, Battery: step 1, image 1 of 1
    • Turn the device over and locate the battery.
  2. Dell Inspiron 15R Screen Replacement: step 2, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 2, image 2 of 2
    • Place thumbs on each latch and push outwards.
  3. Dell Inspiron 15R Screen Replacement: step 3, image 1 of 1
    • Push and slide the battery away from you.
  4. Dell Inspiron 15R Screen Replacement, Keyboard: step 4, image 1 of 3 Dell Inspiron 15R Screen Replacement, Keyboard: step 4, image 2 of 3 Dell Inspiron 15R Screen Replacement, Keyboard: step 4, image 3 of 3
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
  5. Dell Inspiron 15R Screen Replacement: step 5, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 5, image 2 of 2
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
  6. Dell Inspiron 15R Screen Replacement: step 6, image 1 of 1
    • Turn the device around and open it up.
  7. Dell Inspiron 15R Screen Replacement: step 7, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 7, image 2 of 2
    • Using your index finger, push down on the F1 and F7 keys.
  8. Dell Inspiron 15R Screen Replacement: step 8, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 8, image 2 of 2
    • Using your index finger, push down on the x icon and Home keys.
  9. Dell Inspiron 15R Screen Replacement: step 9, image 1 of 3 Dell Inspiron 15R Screen Replacement: step 9, image 2 of 3 Dell Inspiron 15R Screen Replacement: step 9, image 3 of 3
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
  10. Dell Inspiron 15R Screen Replacement: step 10, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 10, image 2 of 2
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
  11. Dell Inspiron 15R Screen Replacement: step 11, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 11, image 2 of 2
    • Carefully pull and turn the keyboard over.
  12. Dell Inspiron 15R Screen Replacement: step 12, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 12, image 2 of 2
    • Lift the black lever.
  13. Dell Inspiron 15R Screen Replacement: step 13, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 13, image 2 of 2
    • Remove the keyboard cable
  14. Dell Inspiron 15R Screen Replacement, Hard Drive: step 14, image 1 of 2 Dell Inspiron 15R Screen Replacement, Hard Drive: step 14, image 2 of 2
    • Turn laptop over and remove the bottom four screw covers outlined in red.
    • Then remove the three base screws.
  15. Dell Inspiron 15R Screen Replacement: step 15, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 15, image 2 of 2
    • Turn laptop over and open it. Locate and remove the five palm rest screws.
  16. Dell Inspiron 15R Screen Replacement: step 16, image 1 of 3 Dell Inspiron 15R Screen Replacement: step 16, image 2 of 3 Dell Inspiron 15R Screen Replacement: step 16, image 3 of 3
    • Locate the palm rest cables. Lift the black levers and unplug the blue cables.
  17. Dell Inspiron 15R Screen Replacement: step 17, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 17, image 2 of 2
    • Lift the palm rest until it snaps off.
  18. Dell Inspiron 15R Screen Replacement: step 18, image 1 of 2 Dell Inspiron 15R Screen Replacement: step 18, image 2 of 2
    • Close cover and turn laptop over. Locate and remove the four hard drive screws.
  19. Dell Inspiron 15R Screen Replacement: step 19, image 1 of 1
  20. Dell Inspiron 15R Screen Replacement: step 20, image 1 of 3 Dell Inspiron 15R Screen Replacement: step 20, image 2 of 3 Dell Inspiron 15R Screen Replacement: step 20, image 3 of 3
    • Lift and remove the hard drive.
  21. Dell Inspiron 15R Screen Replacement: step 21, image 1 of 1
    • Remove the hard drive connector.
  22. Dell Inspiron 15R Screen Replacement, Screen: step 22, image 1 of 2 Dell Inspiron 15R Screen Replacement, Screen: step 22, image 2 of 2
    • Locate and remove the bottom hinge screws.
  23. Dell Inspiron 15R Screen Replacement: step 23, image 1 of 3 Dell Inspiron 15R Screen Replacement: step 23, image 2 of 3 Dell Inspiron 15R Screen Replacement: step 23, image 3 of 3
    • Turn laptop over and open it. Locate and unplug the LCD Cable.
  24. Dell Inspiron 15R Screen Replacement: step 24, image 1 of 3 Dell Inspiron 15R Screen Replacement: step 24, image 2 of 3 Dell Inspiron 15R Screen Replacement: step 24, image 3 of 3
    • Unplug the black and white wires on the wireless antenna.
  25. Dell Inspiron 15R Screen Replacement: step 25, image 1 of 3 Dell Inspiron 15R Screen Replacement: step 25, image 2 of 3 Dell Inspiron 15R Screen Replacement: step 25, image 3 of 3
    • Remove the two hinge screws on both the left and right hand side.
  26. Dell Inspiron 15R Screen Replacement: step 26, image 1 of 1
    • Remove the screen.
Trixie Gonzalez
843 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 2,558
