Dell Inspiron 15z 1570 Display Assembly Replacement
  1. Dell Inspiron 15z 1570 Display Assembly Replacement, Remove the Screws: step 1, image 1 of 2 Dell Inspiron 15z 1570 Display Assembly Replacement, Remove the Screws: step 1, image 2 of 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws on the base of the computer that secure the display assembly to the computer base.
  2. Dell Inspiron 15z 1570 Display Assembly Replacement, Disconnect the Display Cable: step 2, image 1 of 2 Dell Inspiron 15z 1570 Display Assembly Replacement, Disconnect the Display Cable: step 2, image 2 of 2
    • Disconnect the display cable and remove the screw from the system board.
  3. Dell Inspiron 15z 1570 Display Assembly Replacement, Pull the Antenna Cables: step 3, image 1 of 1
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 15z 1570 Display Assembly Replacement, Note the Routing: step 4, image 1 of 1
    • Note the routing of all the cables and remove them from their routing guides.
  5. Dell Inspiron 15z 1570 Display Assembly Replacement, Hold the Display: step 5, image 1 of 1
    • Hold the display while you remove the three screws that secure the display assembly to the computer base.
  6. Dell Inspiron 15z 1570 Display Assembly Replacement, Removing the Display Assembly: step 6, image 1 of 1
    • Lift and remove the display assembly from the computer base.
  7. Dell Inspiron 15z 1570 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 1
    • Using the alignment posts, place the display assembly in position and replace the three screws that secure the display assembly to the computer base.
  8. Dell Inspiron 15z 1570 Display Assembly Replacement, Routing the Cables: step 8, image 1 of 1
    • Route the Mini-Card antenna cables and display cable through their routing guides.
  9. Dell Inspiron 15z 1570 Display Assembly Replacement, Routing the Cables: step 9, image 1 of 1
    • Route the antenna cables through the slot in the computer base.
  10. Dell Inspiron 15z 1570 Display Assembly Replacement, Replace the Screw: step 10, image 1 of 1
    • Replace the screw and connect the display cable.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 166
